Newer GCC version for ESP8266
It seems that the toolchain-xtensa is still using gcc-4.8.x even that newer version seems to be around. Is there a way to manually install newer version with c++14 support?
Thanks for the help
We use the same toolchain which ESP8266 project uses. You can manually update toolchain for your projects.
