I have just started using this program to modify the Marlin Firmware File for a new 3D Printer board.
After I have completed the modifications and and ran the building. I cannot seem to locate the saved file? it says it is saved at “.pio/build/LPC1768/firmware.bin”, which I cannot seem to find?
I am using the program on a Mac.
Folders with . in front of them may be interpreted as hidden folders, at least on Windows. Is there some “show hidden elements” opton in the Mac finder?
You can of course also use a terminal to cd into the path to check if it’s there.
When I go to a hidden folder, I use the “Terminal” program, because I haven’t figured out using “Finder”, maybe it can’t be used!
I have a text document where I save command and path, to get to folders and document or program faster.
