The background: We have some code which uses c++17 features in the application based on the mbed framework. The mbed framework uses the register keyword, which is no longer supported in the C++17 standard. Thus g++ issues a lot of (harmless) warnings. To cut these warnings we can add -Wno-register to the build_flags.
For g++ this is fine. For gcc this results in a lot of
cc1.exe: warning: command line option ‘-Wno-register’ is valid for C++/ObjC++ but not for C
when compiling the mbed framework (or any other C (not C++) library code.
Using extra_scripts is not working, as it seems the CXX_FLAGS option set there are only passed to the application build but not to library builds.
Now the question: What is the way to pass a C++ specific compiler option to the framework or library builds? As explained extra_scripts using the env.Append( CXXFLAGS=[ “-Wno-register” ] ) is not the answer as it seems to work only for the application compiler options.
