Trying to compile using the latest ESP8266/arduino master. The documentation has a section explaining how to use the staging version, but I don’t see a staging version. I was advised to use the master to test a big improvement to SD speed. I’m trying to run the SDspeed test example, but get the same old slow speeds, so trying to figure what’s wrong. The version of ESP8266SdFat appears right (2.0.2) but the speeds do not indicate the improvements in that version. What concerns me is the platform says 2.6.3 which is the latest that I have installed. As far as I know that’s the latest PIO platform.
Would appreciate a dope-slap from someone and advice about how to do this.
> Executing task in folder SD Benchmark: C:\Users\Bob.platformio\penv\Scripts\pio.exe run --target upload <
Processing esp12e (platform: espressif8266; board: nodemcuv2; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 (2.6.3) > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
- framework-arduinoespressif8266 3.0.0-dev+sha.e3fe7a5
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-mklittlefs 1.203.210203 (2.3)
- tool-mkspiffs 1.200.0 (2.0)
- toolchain-xtensa 5.100200.201223 (10.2.0)
Found 40 compatible libraries
|-- <ESP8266SdFat> 2.0.2
| |-- <SPI> 1.0
|-- <SPI> 1.0
Generating .pio\build\esp12e\core\core_version.h
Generating LD script .pio\build\esp12e\ld\local.eagle.app.v6.common.ld
Compiling .pio\build\esp12e\lib878\ESP8266SdFat\FsLib\FsNew.cpp.o
Compiling .pio\build\esp12e\lib878\ESP8266SdFat\common\FmtNumber.cpp.o
Compiling .pio\build\esp12e\lib878\ESP8266SdFat\common\FsStructs.cpp.o
Compiling .pio\build\esp12e\lib878\ESP8266SdFat\common\PrintBasic.cpp.o
