#include <TestTouch.h>
void setup(){
}void loop(){
I Get Error:
src\main.cpp:3:1: error: expected initializer before ‘void’
void setup(){
Any Ideas?
void setup(){
}void loop(){
I Get Error:
void setup(){
Any Ideas?
Can you show the contents of TestTouch.h
And please also add the contents of your platformio.ini
file.
BTW: If you are using the Arduino framework, you should add #include <Arduino.h>
to the top of your main.cpp
. It’s optional if you are using a .ino
file in the Arduino IDE but required for proper C++ and PlatformIO.
TY for taht hint.
Was a missing “;” in TestTouch.h
i knew it was an easy one
