I try to modify an existing library to be able to use it with platformio. The problem, is that library have a unitTests folder with a main.cpp file. When I compile my application, the compiler try to build the unitTests also.
Here a simple platformio.ini
platform = espressif32@3.2.1
build_unflags =
-std=gnu++11
-fexceptions
-DCORE_DEBUG_LEVEL=5
-DDISABLE_PREDEFINED_UNITS
-DENABLE_PREDEFINED_VOLTAGE_UNITS
-DDISABLE_IOSTREAM=ON
-std=gnu++17
platform_packages =
toolchain-xtensa32 @ ~2.80400.0
framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#2.0.0-alpha1
lib_deps = https://github.com/cimeq/units.git
The library is a header only library. So I have added a new library.json file with this content in it.
"name": "units",
"version": "3.0.0",
"description": "This library offert units types",
"repository":
"type": "git",
"url": "https://github.com/cimeq/units.git"
"build" : {
"includeDir" : "include"
"export" : {
"exclude" : [
"unitTests",
".github",
".git",
"3rdParty"
"authors":
"name": "CIMEQ"
"frameworks": "*",
"platforms": "*"
I was in the impression that export/exclude will do the trick of disabling the copy of unitTests folder to libdeps but it’s not working.
If I use the command:
pio package pack
I see the exporting is working within the resulting tar.gz file.
Is there a way of not including this folder to be compiled in ?
Regards
