Hi all,
I’ve written a nice C/C++ codebase running on Arduino Micro. As my project is growing, I decided to make it run on an ESP8266 too.
Most of the code will be unchanged, but some low-level routines have to be environment-specific (e.g. to configure GPIO and PWM).
So I thought about having some .h files with class definitions in /src
, and a pair of .cpp files with the low-level implementations in e.g. /src-arduinomicro
and /src-esp8266
, one per environment, and have the linker consider only one of those directories. But I haven’t found a way to tell PlatformIO to specify additional source directories for each environment.
The only workaround I’ve found, is to specify additional build flags like -DENV_MICRO
and use pairs of #ifdef
…#endif
in each .cpp file that has environment-specific code, but it makes the codebase difficult to read.
So what is the standard way, in PlatformIO, to build specific source files for specific environments?
Thanks & kind regards
Enrico
