Wanted to create multiple Serial port project that would use the 4 hardware serial ports on an Atmel D21 and expose each as a separate virtual serial port (COMx on windows).
I have been able to create two ports, the stock port and a second one but no more show up, I suspect there might be an endpoint limitation, but unsure if that is a hardware or software issue.
Any suggestions?
David
