I am developing a project on the ESP8266/Arduino platform. But I really want to include unittesting for the native platform. For my project, I made a ConfigManager library that uses EEPROM to store config. To test this library, I need an EEPROM implementation for the native platform, which I made called MockEERPOM: lib/MockEEPROM/src · master · Dolf Andringa / aquaman · GitLab
I contains a MockEEPROMClass
and a EEPROM.h
file which only contains the following:
#ifndef EEPROM_h
#define EEPROM_h
#include <MockEEPROM.h>
MockEEPROMClass EEPROM;
The library.json
file for it contains
"platforms": "native"
Now if I understand it correctly, platformio should automatically see the library, realize that it is needed for the platform and compile it and include it. And since there is no EEPROM.h for the native platform, there shouldn’t be an issue with multiple definitions. But for some reason, running the following test with platformio test -e native
results in the following error:
/usr/bin/ld: .pio/build/native/libe9c/libConfigManager.a(ConfigManager.o):(.bss+0x0): multiple definition of `EEPROM'; .pio/build/native/test/test_desktop/test_configmanager.o:(.bss+0x0): first defined here
Any clues what I am doing wrong?
