MQTT loop function flagged as not existing
I have a project that uses ESP32_MQTTClient. When building it I ge this error:
src/main.cpp: In function 'void loop()':
src/main.cpp:203:16: error: 'class ESP32_MQTTClient' has no member named 'loop'
203 | mqttc.loop();
*** [.pio/build/esp32dev/src/main.cpp.o] Error 1
I have tried rebuilding the IntelliSense Index and removing the library from the project and reinstalling. The problem persists. I’m at a loss about what to do next. Any suggestions about how to fix/troubleshoot. This is my .ini file
lib_ldf_mode = chain
    bodmer/TFT_eSPI @ ^2.5.43
    marekburiak/ESP32_MQTTClient@^1.0.0
    -D USER_SETUP_LOADED=1
    -D ILI9341_2_DRIVER=1
    -D TFT_WIDTH=240
    -D TFT_HEIGHT=320
    -D TFT_MISO=12
    -D TFT_MOSI=13
    -D TFT_SCLK=14
    -D TFT_CS=15
    -D TFT_DC=2
    -D TFT_RST=-1
    -D TFT_BL=21
    -D TFT_BACKLIGHT_ON=HIGH
    -D LOAD_GLCD=1
    -D LOAD_FONT2=1
    -D LOAD_FONT4=1
    -D LOAD_FONT6=1
    -D LOAD_FONT7=1
    -D LOAD_FONT8=1
    -D SPI_FREQUENCY=55000000
    -D SPI_READ_FREQUENCY=20000000
    -D SPI_TOUCH_FREQUENCY=25000000
I am attempting to program a ESP32- 2432S028 (CYD)
Thanks for any advice
Are you 100% sure about this? There are tons of similiarly named libraries. This one definitely doesn’t have a .loop() member function, see source code.
However, a library named
bertmelis/espMqttClient@^1.7.3
does have that loop function.
Same for this library
plapointe6/EspMQTTClient@^1.13.3
What other functions do you call on that mqttc object? How do you construct that object? You could narrow it down from there, or just try the given libraries.
