I would like to use the same theme from library code example for the whole PlatformIO & VSCode.
Unluckily, I cannot find anything (neither in platformio-dark.css / aceinna-dark.css)
I digged around also through VSCode and also [HOME].platformio\packages\contrib-piohome\themes.
I discovered the closest theme is Monokai Mega, but it’s not the same.
Does someone have any idea?
The only other choice is to manually create a theme, but at this point I am more curious where the theme is stored.
AFAIK you were looking the right place… it should all be part of .platformio\packages\contrib-piohome and the platformio-dark.css stylesheet. You’ll may also find out there is some form of processing in the minified main javascript file in contrib-piohome. Meaning it’s as simple as copying and pasting it from one theme file to another.
