I’m trying to debug and develop an Arduino library. Searching I’ve found that src_dir, lib_dir & src_filter can be adjusted to work with the libraries examples folder, but I can’t make it work.
My library has this folder structure:
|-src
| |-examples
| | |-Foo
| | L Bar
| | L Bar.ino
| L MyLibrary.h
L platformio.ini
I’ve setup the contents of the platformio.ini file as:
[platformio]
src_dir = src/examples/
lib_dir = src/
default_envs = devel
[env:devel]
src_filter = +<Bar/>
platform = espressif8266
board = nodemcuv2
But when I try to compile it seems to ignore the src_filter setting.
> Executing task: platformio run <
Processing devel (platform: espressif8266; framework: arduino; board: nodemcuv2)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/nodemcuv2.html
PLATFORM: Espressif 8266 2.2.3 > NodeMCU 1.0 (ESP-12E Module)
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
Error: Nothing to build. Please put your source code files to '/mnt/development/MyLibrary/src/examples' folder
====================== [FAILED] Took 1.47 seconds ======================
The environment is linux.
Can someone tell me how to correctly set src_filter or what is the problem?
Thanks very much.
