As you may know, recently we’ve refactored mbed build script and now it uses native mbed tools in order to enable mbed-specific workflow (support for mbed_app.json
config files, original build logic, etc) and several options like PIO_FRAMEWORK_MBED_FILESYSTEM_PRESENT
became unnecessary (like it or not, but mbed tools build the entire framework). Since the mbed framework exists in two forms - mbed 2.0 and mbed OS 5 we decided to keep -DPIO_FRAMEWORK_MBED_RTOS_PRESENT
option to allow the user to switch between these forms. I’m not entirely sure, but filesystem
feature depends on OS functionality and without OS you’ll just get a bunch of compilation errors. But I think it might be possible to add this feature to the project as a standalone library. In any case, please let me know if you are able to compile your code without OS in the online mbed compiler.
And as I mentioned above, the configuration of the project should be done in the mbed_app.json
file, something like this:
"target_overrides": {
"target.features_add": ["STORAGE"],
"target.components_add": ["SD"],
"platform.stdio-baud-rate": 115200,
"target.stdio_uart_tx": "PA_9",
"target.stdio_uart_rx": "PA_10"
