Been stumped on this error; when I try to build a project requiring RTOS on mbed for disco_f769ni I get the following errors:
C:\Users\DesktopX6\.platformio\packages\framework-mbed\rtos\Kernel.cpp: In function 'uint64_t rtos::Kernel::get_ms_count()':
C:\Users\DesktopX6\.platformio\packages\framework-mbed\rtos\Kernel.cpp:37:16: error: 'osKernelGetTickCount' was not declared in this scope
if (sizeof osKernelGetTickCount() == sizeof(uint64_t)) {
rtx_kernal.c where osKernelGetTickCount() is defined can be found in “.platformio\packages\framework-mbed\rtos\TARGET_CORTEX\rtx5\RTX\Source” so I’m not sure where to go with it.
Easiest way to recreate this is to select disco_f769ni from the board menu with mbed as the framework and copy the following example from mbed mbed-os-tcp-server-example
Worth noting that this same issue occurs when trying to do anything even as simple as run a second thread (like you would expect if you can’t find the basis of the RTOS!). Have tried this on two PC’s both running VSCode (1.21.1) with platform IO (0.9.3/3.5.3a8) as clean installs so that should hopefully rule that out.
Might be also worth noting i get the same issue with PlatformIO-IDE for atom…
Compiling .pioenvs\disco_f769ni\libde1\rtos\TARGET_CORTEX\mbed_rtx_handlers.o
C:\Users\sssss\.platformio\packages\framework-mbed\rtos\Kernel.cpp: In function 'uint64_t rtos::Kernel::get_ms_count()':
C:\Users\sssss\.platformio\packages\framework-mbed\rtos\Kernel.cpp:37:16: error: 'osKernelGetTickCount' was not declared in this scope
*** [.pioenvs\disco_f769ni\libde1\rtos\Kernel.o] Error 1
[ERROR] Took 18.38 seconds
Similar issue here. I am working with STM32F103C8T board. Build is OK with standard mbed-framework, but fails with this error when I switch to any version of mbed-dev.
framework-mbed/rtos/Kernel.cpp:37:16: error: 'osKernelGet
Could it be possible that as I’ve only recently installed PlatformIO that it’s downloaded the most recent version of mbed? Though I would have thought there is some sort of version control/unit tests to ensure compatibility.
Not sure that it’s anything to do with the version of framework-mbed as I have tried different versions. What I am trying to do is reduce code to fit my project into 64K of an STM32F103C8. I found that lib_ignore of mbed functions does not have any effect, so I am trying to work with mbed-dev - here is part of my platformio.ini:
[env:genericSTM32F103C8]
platform = GitHub - platformio/platform-ststm32: ST STM32: development platform for PlatformIO
board = bluepill_f103c8
framework = mbed
; build_flags = -DPIO_FRAMEWORK_MBED_RTOS_PRESENT
mbed-dev
lib_ignore = mbed-rtos, mbed-LWIP, mbed-events, mbed-fs, mbed-net, mbed-netsocket, mbed-rpc, mbed-dsp, mbed-USBHost, mbed-USBDevice
Building this generates lots of 'bad instruction' errors, similar to: -
.piolibdeps/mbed-dev_ID2491/cmsis/TARGET_CORTEX_M/TOOLCHAIN_IAR/cmain.S: Assembler messages:
.piolibdeps/mbed-dev_ID2491/cmsis/TARGET_CORTEX_M/TOOLCHAIN_IAR/cmain.S:28: Error: junk at e
nd of line, first unrecognized character is `-'
.piolibdeps/mbed-dev_ID2491/cmsis/TARGET_CORTEX_M/TOOLCHAIN_IAR/cmain.S:29: Error: bad instr
uction `module ?cmain,C-level initialization.'
.piolibdeps/mbed-dev_ID2491/cmsis/TARGET_CORTEX_M/TOOLCHAIN_IAR/cmain.S:33: Error: bad instr
uction `section SHT$$PREINIT_ARRAY:CONST:NOROOT(2)'
Clean default install of either Atom or VS code with platformIO installed. Disco_F769ni board with the mbed framework. This is completely default with no changes.
Hi @nicbkw!
PlatformIO won’t add any libraries that you don’t use in your project, so there is no sense in ignoring all those libraries. Adding mbed-dev also won’t work, since mbed is a framework that requires additional build logic. Have you tried to compile your project with the online mbed compiler? How much RAM do you need to reduce?
Hi @valeros - thanks for the response. I tried mbed and saw that the lib_ignore option did not reduce my code size. I thought that using mbed-dev would work. I understand that using DPIO_FRAMEWORK_MBED_RTOS_PRESENT switches in and out the RTOS library. Are there any complier options I could use to reduce my code size? The project is designed to have an STM32 handle sensors and then link to an 8266 for web server functions. Currently, I am monitoring GPS vis serial, debug via serial and accelerometer & magnetometer (LSM303). Codesize is already over 50kB :
#include "mbed.h"
#include <LSM303.h>
#include <BufferedSerial.h>
static void feedGPS(unsigned long ms);
static int isdigit(char c);
DigitalOut led(PB_12);
Serial gpsSerial(NC, PB_11, 9600);
Serial dbgSerial(PA_2, PA_3, 115200);
// The IMU sensor object
LSM303 lsm;
int heading;
// used as millisecond timer
Timer t;
// variables used to parse GPS
int gpsptr;
char gpschar, gps[128], timestr[16], latstr[16], lonstr[16];
int main() {
printf("GPS test start!\r\n");
lsm.setup();
while(1){
feedGPS(1000);
heading = lsm.getTiltHeading();
printf("heading=%d\r\n", heading);
printf("Lat: %s, Lng: %s %s\r\n", latstr, lonstr, timestr);
//delay loop to parse GPS
static void feedGPS(unsigned long ms) {
t.start();
int begin = t.read_ms();
do{
if (gpsSerial.readable()) {
gpschar = gpsSerial.getc();
if (gpschar == '$')
gpsptr = 0;
else if (gpschar == '\r') {
if (!strncmp(gps, "GPGGA", 5)) {
memset(timestr, 0, sizeof(timestr));
memset(latstr, 0, sizeof(latstr));
memset(lonstr, 0, sizeof(lonstr));
strncpy(timestr, &gps[6], 6);
if (isdigit(gps[16])) {
strncpy(latstr, (const char *)&gps[16], 10);
latstr[10] = gps[27];
strncpy(lonstr, (const char *)&gps[29], 11);
lonstr[11] = gps[41];
else
gps[gpsptr++] = gpschar;
while((t.read_ms() - begin) < ms);
static int isdigit(char c) {
if (c - '0' > -1 and c - '0' < 10)
return 1;
else
return 0;
You can try to use a special version of standard libraries called newlib-nano. To enable it you need to add a special linker flag to the file with default configuration for your board, it’s located here: c:\Users\YOUR_USER\.platformio\packages\framework-mbed\platformio\variants\BLUEPILL_F103C8\BLUEPILL_F103C8.json (Windows) /home/YOUR_USER/.platformio/packages/framework-mbed/platformio/variants/BLUEPILL_F103C8/BLUEPILL_F103C8.json (Linux)
Navigate to the section build_flags and add "--specs=nano.specs to the ld section:
Ok - added the line as suggested to the json file.
My platformi.io file looks like this:
framework = mbed
; lib_deps =
; lib_ignore = mbed-rtos, mbed-LWIP, mbed-events, mbed-fs, mbed-net, mbed-netsocket, mbed-rpc, mbed-dsp, mbed-USBHost, mbed-USBDevice
upload_protocol = stlink
upload_port = /dev/cu.usbmodemFD13423
I now see this error:
/Users/nicbkw/.platformio/packages/framework-mbed/rtos/Thread.cpp:368:24: error: ‘Kernel’ ha
s not been declared
Why am I seeing an RTOS error when I am not uaing the RTOS library?
Thanks
