I am NOT looking on How to convert an Arduino sketch INTO a Platformio project.
I am asking about doing the opposite:
From Platformio into an Arduino sketch.
I have the same question as Leopold.
I have a platformio project and i will open the project in arduino ide. Sorry, but the example in the posted link I dont’ understand…
What should I do?
Thank you!
PlatformIO and Arduino IDE aren’t 100% compatible, but as the example project shows, it doesn’t take much to make it work.
Basically, it’s a matter of:
Creating your project (or open an existing one) - when you do this, you’ll realise where the lib, test and other bits come from).
Renaming the src directory to something, and renaming main.cpp to something.ino (where something is some pertinent name for your project. This meets the Arduino IDE requirement that the .ino must has the same name as the folder containing it.
Editing the platformio.ini file, and adding the following to it (substituting something for the name you used previously):
[platformio]
src_dir = something
That’s pretty much it… if it compiles in PlatformIO, it should compile under the Arduino IDE, assuming you have all the necessary libraries that your project needs installed. All the #includes, function prototypes etc, will be understood by the Arduino IDE because that’s what it’s pre-processor does behind the scenes anyway.
