Hello. I have an application that uses the Arduino framework. Now I would like to port it to “Arduino As a Component” because I need to change some settings to IDF itself (specifically, the RTC clock source).
Following this example: platform-espressif32/examples/espidf-arduino-blink at develop · platformio/platform-espressif32 · GitHub
I can see that the key settings is the platform in the platformio.ini file (framework = arduino, espidf). This so far worked with the example provided. But I see that the IDF configuration (viewing it using menuconfig) it’s different from the Arduino default one (at least it looks like it).
My question is the following:
How can I configure Arduino as a Component to use the same exact configuration as if I were using just plain Arduino (framework = arduino) ?? Is there a settings file I can copy from platformio to mantain the same IDF configuration that worked perfectly with plain Arduino? I don’t want to configure the IDF manually and set something wrong (for example, the partitions table).
Thanks
Gonzalo
