Fresh install of plugin - restart VS Code
From PlatformIO Home page in VS code.
Clicked New Project and added project name
Selected Board Sipeed MaixDuino
Selected Framework Kendryte Standalone SDK
Untick Location Use default
Select new location
Click Finish - fails with this
KeyError: “Invalid board option ‘upload.slow’”:
PIO Core Call Error: “The current working directory S:\VSCode\maixduino\Blinker will be used for the project.\r\n\r\nThe next files/directories have been created in S:\VSCode\maixduino\Blinker\r\ninclude - Put project header files here\r\nlib - Put here project specific (private) libraries\r\nsrc - Put project source files here\r\nplatformio.ini - Project Configuration File\r\n\n\nError: Processing sipeed-maixduino (platform: kendryte210; board: sipeed-maixduino; framework: kendryte-standalone-sdk)\r\n--------------------------------------------------------------------------------\r\nTool Manager: Installing platformio/framework-kendryte-standalone-sdk @ ~0.5.6\r\nTool Manager: framework-kendryte-standalone-sdk @ 0.5.6 has been installed!\r\nVerbose mode can be enabled via -v, --verbose
option\r\nCONFIGURATION: https://docs.platformio.org/page/boards/kendryte210/sipeed-maixduino.html\r\nPLATFORM: Kendryte K210 (1.2.4+sha.e41ccf6) > Sipeed MAIXDUINO\r\nHARDWARE: K210 400MHz, 6MB RAM, 16MB Flash\r\nDEBUG: Current (iot-bus-jtag) External (iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, sipeed-rv-debugger, tumpa)\r\nPACKAGES: \r\n - framework-kendryte-standalone-sdk 0.5.6 \r\n - toolchain-kendryte210 8.2.0\r\nLDF: Library Dependency Finder → http://bit.ly/configure-pio-ldf\r\nLDF Modes: Finder ~ chain, Compatibility ~ soft\r\nFound 0 compatible libraries\r\nScanning dependencies…\r\nNo dependencies\r\nBuilding in release mode\r\nKeyError: “Invalid board option ‘upload.slow’”:\r\n File “C:\Users\marcu.platformio\penv\Lib\site-packages\platformio\builder\main.py”, line 177:\r\n env.SConscript(”$BUILD_SCRIPT")\r\n File “C:\Users\marcu.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py”, line 591:\r\n return _SConscript(self.fs, *files, **subst_kw)\r\n File “C:\Users\marcu.platformio\packages\tool-scons\scons-local-4.1.0\SCons\Script\SConscript.py”, line 280:\r\n exec(compile(scriptdata, scriptname, ‘exec’), call_stack[-1].globals)\r\n File “C:\Users\marcu.platformio\platforms\kendryte210\builder\main.py”, line 108:\r\n “-S” if board.get(“upload.slow”) else “”\r\n File “c:\users\marcu.platformio\penv\lib\site-packages\platformio\platform\board.py”, line 59:\r\n raise KeyError(“Invalid board option ‘%s’” % path)\r\n========================== [FAILED] Took 2.93 seconds =========================="
