I’m attempting to build Marlin using PlatformIO. When I run a build in VSCode or in terminal I get:
wcunning@mycroft-holmes Marlin-2.0.7.2-SKR-mini-E3-V1.2 % pio run
Processing STM32F103RC_btt_512K (platform: ststm32@~6.1; board: genericSTM32F103RC; framework: arduino)
Your PYTHONPATH points to a site-packages dir for Python 3.x but you are running Python 2.x!
PYTHONPATH is currently: "/usr/local/lib/python3.9/site-packages"
You should `unset PYTHONPATH` to fix this.
OSError: 'python Marlin/src/HAL/STM32F1/build_flags.py' exited 1:
File "/usr/local/lib/python3.9/site-packages/platformio/builder/main.py", line 175:
env.SConscript(item, exports="env")
File "/Users/wcunning/.platformio/packages/tool-scons/scons-local-4.1.0/SCons/Script/SConscript.py", line 591:
File "/Users/wcunning/.platformio/packages/tool-scons/scons-local-4.1.0/SCons/Script/SConscript.py", line 280:
File "/Users/wcunning/Documents/3d_print/skr_firmware/BIGTREETECH-SKR-mini-E3/firmware/V1.2/Marlin-2.0.7.2-SKR-mini-E3-V1.2/buildroot/share/PlatformIO/scripts/common-dependencies.py", line 286:
apply_features_config()
File "/Users/wcunning/Documents/3d_print/skr_firmware/BIGTREETECH-SKR-mini-E3/firmware/V1.2/Marlin-2.0.7.2-SKR-mini-E3-V1.2/buildroot/share/PlatformIO/scripts/common-dependencies.py", line 118:
if not env.MarlinFeatureIsEnabled(feature):
File "/Users/wcunning/.platformio/packages/tool-scons/scons-local-4.1.0/SCons/Util.py", line 658:
File "/Users/wcunning/Documents/3d_print/skr_firmware/BIGTREETECH-SKR-mini-E3/firmware/V1.2/Marlin-2.0.7.2-SKR-mini-E3-V1.2/buildroot/share/PlatformIO/scripts/common-dependencies.py", line 262:
load_marlin_features()
File "/Users/wcunning/Documents/3d_print/skr_firmware/BIGTREETECH-SKR-mini-E3/firmware/V1.2/Marlin-2.0.7.2-SKR-mini-E3-V1.2/buildroot/share/PlatformIO/scripts/common-dependencies.py", line 233:
build_flags = env.ParseFlagsExtended(build_flags)
File "/usr/local/lib/python3.9/site-packages/platformio/builder/tools/platformio.py", line 185:
for key, value in env.ParseFlags(str(raw)).items():
File "/Users/wcunning/.platformio/packages/tool-scons/scons-local-4.1.0/SCons/Environment.py", line 821:
do_parse(arg)
File "/Users/wcunning/.platformio/packages/tool-scons/scons-local-4.1.0/SCons/Environment.py", line 673:
arg = self.backtick(arg[1:])
File "/Users/wcunning/.platformio/packages/tool-scons/scons-local-4.1.0/SCons/Environment.py", line 585:
raise OSError("'%s' exited %d" % (command, status))
==================================================================== [FAILED] Took 0.46 seconds ====================================================================
Environment Status Duration
STM32F103RC_btt_512K FAILED 00:00:00.461
=============================================================== 1 failed, 0 succeeded in 00:00:00.461 ===============================================================
As a sanity check, I ran the following:
wcunning@mycroft-holmes Marlin-2.0.7.2-SKR-mini-E3-V1.2 % which python
python: aliased to /usr/local/bin/python3
wcunning@mycroft-holmes Marlin-2.0.7.2-SKR-mini-E3-V1.2 % python --version
Python 3.9.1
wcunning@mycroft-holmes Marlin-2.0.7.2-SKR-mini-E3-V1.2 % pio system info
PlatformIO Core 5.1.0
Python 3.9.1-final.0
System Type darwin_x86_64
Platform macOS-11.2
File System Encoding utf-8
Locale Encoding UTF-8
PlatformIO Core Directory /Users/wcunning/.platformio
PlatformIO Core Executable /usr/local/bin/platformio
Python Executable /usr/local/opt/python@3.9/bin/python3.9
Global Libraries 0
Development Platforms 2
Tools & Toolchains 12
Why the heck is it still thinking that it’s running Python2.7? This is OSX 11.2 with Homebrew recently updated.
