Lpmsp430fr6989 unknow MCU HEader
Okay working on this some more this morning. I pulled down the latest build of mspdebug as posted in the forum. I would really like to install it in the PIO environment so i can use it integrated with the IDE as advertised. However, PIO is denying make permission to install the executable in the pio directory. Here is some terminal output:
warren@warren-XPS-15-9560:~/Repositories/mspdebug/mspdebug$ make install
mkdir -p ./platformio/packages/tool-mspdebug/bin/
./platformio/packages/tool-mspdebug -m 0755 mspdebug ./platformio/packages/tool-mspdebug/bin/
make: execvp: ./platformio/packages/tool-mspdebug: Permission denied
Makefile:124: recipe for target 'install' failed
make: *** [install] Error 127
warren@warren-XPS-15-9560:~/Repositories/mspdebug/mspdebug$ sudo make install
I am not a super expert on make so I may not have configured this properly. Anyone got any ideas on how to get this to work?
That is not a problem with PIO. I think that is a problem with system permission. Try to remove ./platformio/packages/tool-mspdebug folder
Should i remove only the tool-msp430 debug folder? i removed it and tried the make install again and still got permissions error.
  1. Please remove ./platformio/packages/tool-mspdebug
  2. Build mspdebug in separate fodler
  3. Run platformio run --target upload
  4. Replace new files in ./platformio/packages/tool-mspdebug
Okay, cloned the repo and build the executable. removed mspdebug and copied the new mspdebug into the .platformio/packages/tool-mspdebug
ran upload… here is the output. Looks like the .so file is not what mspdebug is expecting.,
MSPDebug version 0.22 - debugging tool for MSP430 MCUs
Copyright (C) 2009-2013 Daniel Beer dlbeer@gmail.com
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
tilib: can’t find libmsp430.so: libmsp430.so: wrong ELF class: ELFCLASS32
  4. Replace mspdebug_bin in ./platformio/packages/tool-mspdebug with compiled file. Please keep the same name mspdebug_bin.
The entire MSP430 development platform is obsolete?!
What about these dev-kits:
So are you saying we should not expect TI MSP430 support in PIO?
Please file a feature request here Issues Ā· platformio/platform-titiva Ā· GitHub
Please file an issue here Issues Ā· platformio/platform-timsp430 Ā· GitHub
