Is it possible to do specify a local path for a patform_package like so:
platform_packages =
framework-foobar @ ~/src/foobar
If so, how can I achieve such result?
platform_packages =
I’d also like to note however that the platform_packages
only really make sense when it’s a link to a internet website / repository, otherwise it’s not reproducible upon other computers without special setup.
That, or developing stuff locally, before packaging it up…
It should work but will try to copy contents of package instead of using it as a symlink. I remember someone opened an issue for this case.
When I try to do it, the following happens:
Processing esp32dev (platform: espressif32; framework: arduino, espidf; board: esp32dev)
PackageManager: Installing framework-espidf @ ~/Development/esp-idf
Warning! Package Mirror: Package version 3.40000.200303 doesn't satisfy requirements ~/Development/esp-idf
Looking for another mirror...
Error: Could not install 'framework-espidf' with version requirements '~/Development/hyper/esp-idf' for your system 'darwin_x86_64'.
Please try this solution -> http://bit.ly/faq-package-manager
Using a symlink now works:
platform_packages =
platformio/framework-arduinoespressif32 @ symlink://C:/Users/user/arduino-esp32
