I wasn’t able to reproduce your issue with a minimal example.
If I write the platformio.ini
as
[env:nanoatmega328]
board = nanoatmega328
and src\main.cpp
as
#include "test_inline.h"
static const gio_t led_pin = GIO_INIT(B, 1);
gioSetModeOutput(&led_pin);
with src\test_inline.h
as
#ifndef TEST_INLINE_H
#define TEST_INLINE_H
#include <stdint.h>
typedef struct
volatile uint8_t *const pin; // The pin registry memory location
volatile uint8_t *const ddr; // The data direction registry memory location
volatile uint8_t *const prt; // The port registry memory location
const uint8_t bit; // The bit number
} gio_t;
#define GIO_INIT(_PORT_LTR, _BIT_NR) \
&PIN##_PORT_LTR, &DDR##_PORT_LTR, &PORT##_PORT_LTR, P##_PORT_LTR##_BIT_NR \
#ifdef __cplusplus
extern "C"
inline void gioSetModeOutput(const gio_t *const _gio)
*(_gio->prt) &= ~_BV(_gio->bit);
*(_gio->ddr) |= _BV(_gio->bit);
#ifdef __cplusplus
then compilation results in a success in the latest platform version (and GCC 7.3.0)
Processing nanoatmega328 (platform: atmelavr; board: nanoatmega328; framework: arduino)
------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/nanoatmega328.html
PLATFORM: Atmel AVR (3.2.0) > Arduino Nano ATmega328
HARDWARE: ATMEGA328P 16MHz, 2KB RAM, 30KB Flash
- framework-arduino-avr 5.1.0
Found 11 compatible libraries
Compiling .pio\build\nanoatmega328\src\user_main.cpp.o
Archiving .pio\build\nanoatmega328\libFrameworkArduinoVariant.a
Compiling .pio\build\nanoatmega328\FrameworkArduino\CDC.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\HardwareSerial0.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\HardwareSerial1.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\HardwareSerial2.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\HardwareSerial3.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\PluggableUSB.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\Print.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\Tone.cpp.o
Indexing .pio\build\nanoatmega328\libFrameworkArduinoVariant.a
Compiling .pio\build\nanoatmega328\FrameworkArduino\USBCore.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\WInterrupts.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\WString.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\abi.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\hooks.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\main.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\new.cpp.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring_analog.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring_digital.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring_pulse.S.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\nanoatmega328\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\nanoatmega328\libFrameworkArduino.a
Indexing .pio\build\nanoatmega328\libFrameworkArduino.a
Linking .pio\build\nanoatmega328\firmware.elf
Building .pio\build\nanoatmega328\firmware.hex
Checking size .pio\build\nanoatmega328\firmware.elf
RAM: [ ] 0.4% (used 9 bytes from 2048 bytes)
Flash: [ ] 1.5% (used 448 bytes from 30720 bytes)
======================== [SUCCESS] Took 2.08 seconds ========================
However maybe the newer compiler or C/C++ version handles these inline
functions differently at which it is failing here (at gioSetModeOutput()
). Here is an article with some remarks to inline functions and linking, maybe one of those options help (like static inline
, __attribute__((alway_inline))
, namespaces, removing the inline
as a test or whatever). Or maybe the behavior changes as multiple C++ files include the header, or a C file includes the header…
If that does not help, is the full project code available somewhere?
