Why are libraries not found when using ‘platform = windows_x86’ ?
A simple project using one library dependency does not work, that is the LDF does not find the library and says the source header file is not found.
This project does not work
[env:windows_x86]
lib_deps = chris--a/BitBool@^1.2.0
then this main.cpp in src folder
#include <stdio.h>
//#define USE_STANDARD_BOOL
#define MAX_ITEMS 100
#include <BitBool.h>
#ifdef USE_STANDARD_BOOL
bool b_Array[ MAX_ITEMS ] = { true, true, true };
#else
BitBool< MAX_ITEMS > b_Array = { B00000111 };
void test()
bool b_TempCopy = b_Array[ MAX_ITEMS - 1 ];
//Roll items up.
for( int i_Index = MAX_ITEMS - 1 ; i_Index ; --i_Index )
b_Array[ i_Index ] = b_Array[ i_Index - 1 ];
b_Array[ 0 ] = b_TempCopy;
//Show contents.
printf("[");
for( int i_Index = 0 ; i_Index < MAX_ITEMS ; ++i_Index )
printf("%c", b_Array[ i_Index ] ? '#' : '-' );
printf("]\r\n");
int main(int argc, char *argv[])
printf("run bit bool test\n");
test();
