I created my first library and I’m trying to install it (tried it as a local folder, with git and from the package registry). But somehow I can’t include my files. I looked in the c_cpp_properties.json
file and although my library gets installed with all its files in the .pio/libdeps
folder, there is no entry created for it in the c_cpp_properties.json
. Do you have any suggestions what the problem might be?
The library dependency (LDF) probably has to recognize the usage of the library first, so do a #include <lib_header_file.h>
in your code and build it once, then the IntelliSense should rebuild. If it’s not there, do a Ctrl+Shift+P → Rebuild IntelliSense to force a rebuild.
Thanks for the quick reply!
Is not working when I use it with my library:
#include <LuaOnArduino.h>
I get the compile error:
src\main.cpp:3:26: fatal error: LuaOnArduino.h: No such file or directory
I see. Compatibility checks & wrong manifest info prevents the library from being included properly.
teensy
is not a framework, it’s a platform (a platform always refer to a type of microcontroller platform, here platform-teensy
). If you only want this to be compatible with platform = teensy
projects, put it as platforms
. But why limit it to teensy
? You can also set *
for ‘everything’.
A framework
is the underlying code base / SDK, same as the available framework = ..
choices in the platformio.ini
for a board. For example, arduino
, espidf
, simba
, … See here.
Correct the library.json
, remove the .pio
folder of the project again and rebuild (assuming you’re pointing to the library via the git link https://github.com/lua-on-arduino/arduino.git
that should trigger a redownload of the lib).
It worked! Thank you so much for your help!
I wanted to restrict it to teensy because this is the only platform I have tested, but it should work with all platforms I guess
