I am trying to use travic CI to build my project. My project builds correctly on my local windows 10 machine. On travis CI I get a file not found error on a library (WiFiManager) installed through the library manager.
Note sure what’s going on there… I enabled Travis on a project that uses WifiManager, and it ran fine:
Since you have an earlier error at line #59fatal: No names found, cannot describe anything. in relation to the linker script, I’d be thinking about first switching back to the stock platformio-espressif8266, rather than the staging version just in case there is something broken along there. I haven’t run that project on newer versions of the espressif8266 core than 2.2.1 (as you can see from the project’s platformio.ini I have it version locked) so I could also just be lucky and not running a bugged version.
