PlatformIO Registry is not being updated for some reason. library.json
is fine AFAICS esp8266-weather-station/library.json at master · ThingPulse/esp8266-weather-station · GitHub and there are tags for each version in the GitHub repo.
What did I miss?
It appears it’s also listed under PlatformIO Registry - and that one did get updated. The aim is to match what we have in the Arduino libs registry.
I do not remember how those two entries in your registry came to be. According to Creating Library — PlatformIO latest documentation we must have manually published them at some point in the past. However, that documentation also says we need to manually republish every release. I suspect that’s only partially correct as you seem to be crawling some (other) registries for new releases? Where would I find information on that?
The way I remember it, some (older or when requested?) repos are in auto-crawl mode, if not pio pkg publish
must be done.
CC @ivankravets
We obviously ended up with this lib listed twice. How can we delist one of them?
How do we find out about auto-crawl yes/no?
Please also remove library.json
file from the project if you don’t want to align manifests. They point to different library names. It is not allowed in the PlatformIO Registry. We recommend using the same library name which you use for the Arduino registry. So, this library is good:
Thanks! I was able to publish it to the correct owner.
Can you please also delete “thingpulse/WeatherStation”. I had first manually published it under the wrong name.
Do we now have to publish every new release manually or will you sync it from the Arduino registry?
Also, can you somehow limit which PIO accounts can publish to the “thingpulse” owner?
Done
Now, yes, because you published manually a new version. You can set up automatic publishing with Github Actions CI. See lvgl/.github/workflows/platformio_publish.yaml at master · lvgl/lvgl · GitHub
Please note that you will need to generate your own access token. See pio account
command.
You are the only owner of thingpulse
org. Noone can publish new versions.
