Again, this is incorrect workflow. The right solution is to add library.json
and specify extra -Irelative/path
to build_flags
If you don’t want do that and want to have “each” inc
folder as separate folder, the better is here to use lib_extra_dirs :
[platformio]
lib_extra_dirs = /path/to/FreeRTOS, /path/to/FreeRTOS/FreeRTOS/source/include, ........
[env:yourenv]
Incorrect. The right is:
[platformio]
lib_extra_dirs = L:/User/Carl Home/My Documents/arduino/sketchbook/libraries
[env:esp12e]
cgiff50
December 16, 2016, 1:00pm
23
Thanks Ivan, I’ll change platform.ini and recompile.
I appreciate everyone’s input and discussion on this subject.
Ivan, can you point me to an example of adding library.json. Thanks.
Sure, please take a look at Microbit-DAL library. You need to place library.json
to the root of your library:
Thank you. On a side note, I see my paths are in gccIncludePaths in .gcc-flags.json. Why is the compiler not finding the files?
joe31093:
.gcc-flags.json
PIO generates this file for PlatformIO IDE to provide real code linting basing on build environment. Please don’t see on that file.
