Hi folks.
[env:d1_mini]
platform = espressif8266
board = d1_mini
blynkkk/Blynk@^1.0.1
gyverlibs/GyverPortal
This platformio.ini config causes an error
.pio\libdeps\d1_mini\Blynk\src/BlynkSimpleEsp8266.h:21:2: error: #error Please update your ESP8266 Arduino Core
Reason of this is that
#include <version.h>
in BlynkSimpleEsp8266.h:21:2
from Blynk
library include ‘version.h’ from GyverPortal
library. Not from framework-arduinoespressif8266
. So ESP_SDK_VERSION_NUMBER
was undefined and cause this error. How to resolve this? Thanks in advance.
Well are you using the latest version? Either update via PIO Home → Platforms → Espressif 8266 → Update or open a CLI → pio pkg update -g -p espressif8266
@maxgerhardt
Yes. I use last version. ESP_SDK_VERSION_NUMBER
defined as 0x020200.
Problem is that #include <version.h>
include #include <version.h>
not from framework-arduinoespressif8266
but from other lib (GyverPortal). Of course I can remove
#if ESP_SDK_VERSION_NUMBER < 0x020200
from BlynkSimpleEsp8266.h
. In this case all build and work fine. But share code that not work from box to other users is a not good idea.
