Lgt8f328p with Platformio and VSCode - unknown platform
Thanks a lot!!
Couldn’t find it here: platform_packages
But there: local-folder
Sorry …
Now, with replaced Radiohead Lib, the code compiles without problems:
Compiling .pio\build\LGT8F328P\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\LGT8F328P\libFrameworkArduino.a
Linking .pio\build\LGT8F328P\firmware.elf
Building .pio\build\LGT8F328P\firmware.hex
Checking size .pio\build\LGT8F328P\firmware.elf
RAM:   [====      ]  44.3% (used 907 bytes from 2048 bytes)
Flash: [======    ]  64.9% (used 19266 bytes from 29696 bytes)
=========================================== [SUCCESS] Took 6.86 seconds ===========================================
… but “inspection” fails the same way - break after about 10% memory check and the only result is
“Invalid params” (like previous screenshot).
Changed the “platformio.ini”:
[env:LGT8F328P]
platform = https://github.com/darkautism/pio-lgt8fx.git
platform_packages =
   framework-arduino-avr-lgt8f@symlink://C:\Users\XYXY\.platformio\packages\lgt8f-2.0.6\lgt8f
board = LGT8F328P
monitor_speed = 57600
upload_speed = 57600
board_build.f_cpu = 16000000L
board_build.clock_source = 1
	;jgromes/RadioLib@^6.0.0
	jgromes/LoRaLib@^8.2.0
	adafruit/Adafruit BMP280 Library@^2.6.8
	adafruit/Adafruit Si7021 Library@^1.5.1
	adafruit/Adafruit Unified Sensor@^1.1.9
[platformio]
description = LoRa Sensor Node
Uses slightly more memory:
RAM:   [====      ]  44.8% (used 917 bytes from 2048 bytes)
Flash: [=======   ]  67.8% (used 20124 bytes from 29696 bytes)
=========================================== [SUCCESS] Took 6.37 seconds ===========================================
But, no change to the results of “Inspect”.
