Hi all,
I’ve found a PlatformIO platform/board bug.
I just created a new empty project for:
[env:frdm_kl05z]
platform = freescalekinetis
board = frdm_kl05z
framework = mbed
The source code is empty, main() just loops, nothing else.
On build i get:
Generating LD script .pio\build\frdm_kl05z\MKL05Z4.ld.link_script.ld
Linking .pio\build\frdm_kl05z\firmware.elf
c:/users/mark/.platformio/packages/toolchain-gccarmnoneeabi/bin/…/lib/gcc/arm-none-eabi/7.2.1/…/…/…/…/arm-none-eabi/bin/ld.exe:.pio\build\frdm_kl05z\MKL05Z4.ld.link_script.ld:80: syntax error
*** [.pio\build\frdm_kl05z\firmware.elf] Error 1
MKL05Z4.ld.link_script.ld contains:
.heap : { __end__ = .; end = __end__; *(.heap*) .= ORIGIN(RAM) + LENGTH(RAM) - STACK_SIZE; __HeapLimit = .; } > RAM
The error is the ".= ORIGIN(RAM) … " line.
BTW… is there a better place to report this to the devs than here?
Thanks.
