Keyword new in constructor crashes
Below are two versions, both crashes. Why?
I am using platformIO with Arduino, have tested on two different ES32 to rule out hardware problems.
class testNewClass2 {
  public:
    testNewClass2() : p1(new char(20)) {    }
    char *p1;
class testNewClass3 {
  public:
    testNewClass3() {
      p1 = new char(10);
    char *p1;
With what platformio.ini and full src/main.cpp is that? Used package versions?
I made a new complete project that worked.
As expected I guess.
However, the example is part of a test project for ArduinoHA.h where the problem showed up first time.
I will go back and start over to from scratch.
Just of curiosity; have you any idea how/why such a simple example can fail (without having the complete code)?
Anyway, thank you replying.
I wouldn’t rely on guessing based on incomplete code. If you can reproduce it, and get a backtrace, then that can be decoded and understood.
Did you mean parentheses or square brackets?
You’re initializing a single character to a value, not an array of a given length, but I’m not sure what you’re trying to do.
I think levin is on the right track. you should give new a type, not a constant of some type. I am a bit surprised this crashes. I‘d expect your examples to produce compiler errors.
Sorry for not responding for a few days but I found the error.
Thank you lewin and joba, you are absolutely right; I used parenthesis instead of square brackets. A silly mistake that took hours to find since it worked in a few cases but more often it crashed.
