Hello !
I have a question related to library.
When creating a project on atom, for arduino, esp8266, whatever, it will be created an src and lib directory.
Most of library I use are from library manager: I search and “install” them from the library gui in atom/platformio.
Then, I use github to manage and store my code.
Is there a way to automatically create a copy of library I use in my_project/lib directory ?
I would like to make sure I can freeze in github a full copy of my code, including library.
If the libraries you are using are from the library manager, use your platformio.ini
file lib_deps
parameter to specify libraries your project needs, and if you want a specific version, that specific version… then you don’t need the distribute the library… it will be automatically installed (to the .piolibdeps
folder).
https://docs.platformio.org/en/latest/projectconf/section_env_library.html#lib-deps
Hi !!!
I’m very sorry, I missed the answer to my post and just discover now!
The issue is still valid
Can I just do like this :
[env:d1_mini_pro]
platform = espressif8266
board = d1_mini_pro
PubSubClient@2.7
PCF8583@1.0.0
My expectation is that it will stick to pubsubclient v2.7 & PCF8583 v1.0.0 (those libs are installed from platformIO library) even if I update my libs ?
My intention is that I can then freeze all used libs when I want to release a working code.
Ah, while having a look in “PIO Home” (in vscode), I notice that each lib has an “installation” tab that just show perfect examples with various situation on how to do what I need
I add a screenshot in case it helps some other:
Yes, exactly. For example, this is the configuration for code I’m currently working on…
platform = espressif8266@2.3.0
PCA9685 16-Channel PWM Driver Module Library@1.2.9
ESPAsyncTCP@1.2.0
ESP Async WebServer@1.2.0
ESPAsyncWiFiManager@0.20
AsyncMqttClient@0.8.2
… and it locks not just the version of the libraries, but also the platform/core version, (2.3.0 = esp8266/arduino 2.6.1, 2.3.1 = 2.6.2).
