Just upgraded to platformio 2.0.0-rc2. Had issues, uninstalled all platformio-* plugins, the installed.
Same issue.
This following error appears on the JS console several thousand times (38263 times to be exact)
Errored result: {“jsonrpc”:“2.0”,“id”:“0.027675620954959568”,“error”:{“rawStack”:[{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{},{}],“message”:“Server error”,“code”:-32000}}
Stacktrace:
sock.onmessage @ /Users/username/.atom/packages/platformio-ide/node_modules/platformio-node-helpers/lib/index.js:1663
EventTarget.dispatchEvent @ /Users/username/.atom/packages/platformio-ide/node_modules/sockjs-client/lib/event/eventtarget.js:51
(anonymous) @ /Users/username/.atom/packages/platformio-ide/node_modules/sockjs-client/lib/main.js:274
SockJS._transportMessage @ /Users/username/.atom/packages/platformio-ide/node_modules/sockjs-client/lib/main.js:272
emitOne @ events.js:96
emit @ events.js:188
(anonymous) @ /Users/username/.atom/packages/platformio-ide/node_modules/sockjs-client/lib/transport/lib/sender-rec…:23
(anonymous) @ /Users/username/.atom/packages/platformio-ide/node_modules/sockjs-client/lib/transport/lib/polling.js:30
EventSourceReceiver.es.onmessage @ /Users/username/.atom/packages/platformio-ide/node_modules/sockjs-client/lib/transport/receiver/event…:21
_emit @ /Users/username/.atom/packages/platformio-ide/node_modules/eventsource/lib/eventsource.js:172
parseEventStreamLine @ /Users/username/.atom/packages/platformio-ide/node_modules/eventsource/lib/eventsource.js:186
(anonymous) @ /Users/username/.atom/packages/platformio-ide/node_modules/eventsource/lib/eventsource.js:150
readableAddChunk @ _stream_readable.js:176
Readable.push @ _stream_readable.js:134
parserOnBody @ _http_common.js:123
socketOnData @ _http_client.js:362
onread @ net.js:551
Any ideas?
