Sorry for the primitive question, but i’m really inconvenienced by having to type in line by line
pio run -t upload
pio device monitor -f esp32_exception_decoder
Attempting to enter pio run -t upload -t monitor -f esp32_exception_decoder prompts me to read the help. Maybe there is a solution to how to combine these two actions into one line.
Well indeed
Usage: pio run [OPTIONS]
Try 'pio run -h' for help.
Error: no such option: -f
The pio run
command does not take a -f
(filter) argument like pio device monitor
does. You should put that in your platformio.ini
using the monitor_filters
directive. Then pio run -t upload -t monitor
should work as expected.
Thanks!
This works great!
;https://docs.platformio.org/en/latest/core/userguide/device/cmd_monitor.html#filters
