I tried to debug using Jlink, but I can’t. What did I miss?
Warning! Unknown upload protocol jlink-jtag
undefinedC:\Users\JJS\.platformio\packages\toolchain-xtensa-esp32\bin\xtensa-esp32-elf-gdb.exe: warning: Couldn't determine a path for the index cache directory.
Reading symbols from d:\Project\HVP\FreeRTOS_test_230116\.pio\build\esp-wrover-kit\firmware.elf...
PlatformIO: debug_tool = jlink
Open On-Chip Debugger v0.11.0-esp32-20220706 (2022-07-06-15:48)
Licensed under GNU GPL v2
For bug reports, read
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Warn : Failed to open device: LIBUSB_ERROR_NOT_SUPPORTED.
Error: No J-Link device found
[env:esp-wrover-kit]
build_type = debug
debug_tool = jlink
upload_protocol = jlink-jtag
bodmer/TFT_eSPI@^2.4.79
lvgl/lvgl@^8.3.2
-DBOARD_HAS_PSRAM
-mfix-esp32-psram-cache-issue
; -DCONFIG_FREERTOS_USE_TRACE_FACILITY
H/W connection
TMS: IO14
TDI: IO12
TCK: IO13
TDO:IO15
VCC: 3.3V
GND: GND
Jlink driver: WinUSB Driver (by using Zadig)
run InstDrivers.exe in core_dir/packages/tool-jlink/USBDriver
Then it’s a driver issue. Can you uninstall the driver installed by Zadig again, or try WinUSB instead of libusb in Zadig?
I have tried those as below. But debugging with J-Link dose not work.
debug_tool = jlink
build_type = debug
- PIO debug result is shown as below:
undefined'platformio'��(��) ���� �Ǵ� �ܺ� ����, ������ �� �ִ� ���α�, �Ǵ�
��ġ ������ �ƴմϴ�.
- if the upload_protocol = jlink, the upload result is shown as below:
AVAILABLE: cmsis-dap, esp-bridge, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = jlink
Uploading .pio\build\esp32dev\firmware.bin
debug_level: 1
** Programming Started **
** Programming Finished in 5228 ms **
** Verify Started **
** Verify OK **
** Programming Finished in 1426 ms **
** Verify OK **
** Programming Finished in 1104 ms **
** Verify OK **
** Programming Finished in 1197 ms **
** Verify OK **
shutdown command invoked
========================================= [SUCCESS] Took 15.50 seconds =========================================
--- Available ports:
--- Enter port index or full name:
- if the upload_protocol = jlink-jtag, the upload result is shown as below:
========================================= [SUCCESS] Took 45.97 seconds =========================================
When I created my esp32dev pio project, there were c_cpp_properties.json, extensions.json and launch.json in the .vscode folder. If I click the PIO Debug, I got an error message with “Could not find the specified task”.
my launch.json file is as below:
"version": "0.2.0",
"configurations": [
"type": "platformio-debug",
"request": "launch",
"name": "PIO Debug",
"executable": "c:/Users/JJS/Documents/PlatformIO/Projects/230126-094810-arduino-blink/.pio/build/esp32dev/firmware.elf",
"projectEnvName": "esp32dev",
"toolchainBinDir": "C:/Users/JJS/.platformio/packages/toolchain-xtensa-esp32/bin",
"internalConsoleOptions": "openOnSessionStart",
"preLaunchTask": {
"type": "PlatformIO",
"task": "Pre-Debug"
I created tasks.json in .vscode as below, then the debugging was successful.
"version": "2.0.0",
"tasks": [
"label": "Pre-Debug",
"type": "shell",
"command": "pio run",
"group": {
"kind": "build",
"isDefault": true
It’s fortunate that it was debugged, but I wonder why I need to create a tasks.json file in this project debugging with J-Link. Even when debugging with FTDI in the esp-wrover-kit project, there was a preLaunchTask item in the launch.json file, but tasks.json was not created and debugging was successful.
