It appears that there is a binary loading issue for J-link on catalina currently. This works fine on linux for me but on my mac it returns
Linking .pio/build/nrf52_express/firmware.elf
Checking size .pio/build/nrf52_express/firmware.elf
DATA: [ ] 4.5% (used 11276 bytes from 248832 bytes)
Building .pio/build/nrf52_express/firmware.hex
PROGRAM: [= ] 8.9% (used 72432 bytes from 815104 bytes)
AVAILABLE: jlink, nrfjprog, nrfutil, stlink
CURRENT: upload_protocol = jlink
Uploading .pio/build/nrf52_express/firmware.hex
SEGGER J-Link Commander V6.52 (Compiled Sep 27 2019 17:51:12)
DLL version V6.52, compiled Sep 27 2019 17:51:01
J-Link Command File read successfully.
Processing script file...
J-Link connection not established yet but required for command.
Connecting to J-Link via USB...FAILED: Failed to open DLL
Script processing completed.
It returns code 0 but the device is never updated
I can successfully use J-Link (V8 and V9) with PlatformIO and a nRF52832 Bluefruit Feather board on macOS Catalina.
What version of the J-Link adapter are you using?
According to your log, the problem seems to be with the USB communication. Can you check another cable and another USB port?
I have a J-link light rev v8.1
The cable works fine on my linux box, I tried both a different port and different USB-C to A adapter. The message makes me a bit weary of the idea of a hardware issue. Its almost like the driver isn’t linking properly.
It seems like it fails to load a DLL / dynalib, but is quiet about which file >_>.
Following this mention you might need to install libusb. You can get brew and then use brew install libusb
Otherwise we’d need to see a verbose upload log (pio run -t upload -v
) and see if we can get a manual invocation of the JLink.exe working. If dynamic DLL loading still fails, we’d maybe have to use a system call tracer…
I will give that a shot tonight. I just remembered that have been able to use the j-link outside pio to flash the bootloader so the system can use it, its just PIO that is confused.
libusb is already installed
Processing nrf52_express (board: adafruit_feather_nrf52840_s340; framework: arduino; platform: nordicnrf52; platform_packages: framework-arduinoadafruitnrf52 @ https://github.com/cujomalainey/Adafruit_nRF52_Arduino; upload_protocol: jlink)
CONFIGURATION: https://docs.platformio.org/page/boards/nordicnrf52/adafruit_feather_nrf52840_s340.html
PLATFORM: Nordic nRF52 4.0.0 > Adafruit Feather nRF52840 Express
HARDWARE: NRF52840 64MHz, 243KB RAM, 796KB Flash
DEBUG: Current (jlink) External (jlink, stlink)
PACKAGES: toolchain-gccarmnoneeabi 1.70201.0 (7.2.1), framework-arduinoadafruitnrf52 459a94d (git+https://github.com/cujomalainey/Adafruit_nRF52_Arduino), tool-sreccat 1.164.0 (1.64), tool-openocd 2.1000.190707 (10.0), tool-jlink 1.65200.0 (6.52.0), tool-bossac-nordicnrf52 1.10866.191129 (1.8.66)
Warning! Cannot find an appropriate softdevice binary!
Found 10 compatible libraries
|-- <Adafruit Bluefruit nRF52 Libraries> 0.14.5 (/Users/curtismalainey/.platformio/packages/framework-arduinoadafruitnrf52@src-a3397c4684d09776374b404e065175e0/libraries/Bluefruit52Lib)
| |-- <Adafruit Little File System Libraries> 0.11.0 (/Users/curtismalainey/.platformio/packages/framework-arduinoadafruitnrf52@src-a3397c4684d09776374b404e065175e0/libraries/Adafruit_LittleFS)
| |-- <Adafruit Internal File System on Bluefruit nRF52> 0.11.0 (/Users/curtismalainey/.platformio/packages/framework-arduinoadafruitnrf52@src-a3397c4684d09776374b404e065175e0/libraries/InternalFileSytem)
MethodWrapper(["checkprogsize"], [".pio/build/nrf52_express/firmware.elf"])
DATA: [ ] 4.5% (used 11148 bytes from 248832 bytes)
PROGRAM: [= ] 8.8% (used 72136 bytes from 815104 bytes)
.pio/build/nrf52_express/firmware.elf :
section size addr
.text 71452 200704
.ARM.exidx 8 272156
.data 676 536895488
.bss 10472 536896164
.heap 224372 536906636
.ARM.attributes 50 0
.comment 126 0
.debug_frame 5040 0
.stab 180 0
.stabstr 387 0
Total 312763
<lambda>(["upload"], [".pio/build/nrf52_express/firmware.hex"])
JLinkExe -device nRF52840_xxAA -speed 4000 -if swd -autoconnect 1 -CommanderScript "/Users/curtismalainey/Github/ant-arduino/.pio/build/nrf52_express/upload.jlink"
================================================================================================================ [SUCCESS] Took 2.28 seconds ================================================================================================================
Environment Status Duration
teensy31-arduino IGNORED
teensy31-mbed IGNORED
native IGNORED
huzzah32 IGNORED
nrf52_express SUCCESS 00:00:02.278
================================================================================================================ 1 succeeded in 00:00:02.278 ================================================================================================================
The upload.jlink contains the following
h
loadbin .pio/build/nrf52_express/firmware.hex,0x0
r
q
No idea what that script is about
Have you resolved this issue?
Haven’t had much time to work on projects since COVID started. will check once i get the chance.
I had similar problem. I resolved it on my Mac by downloading SEGGER - The Embedded Experts - Downloads - J-Link / J-Trace for my mac, installing it and then restarting the computer.
Hope it helps to anyone end up on this thread.
Hmm I tried that before but will try again with 5.0. Thanks
