I’ve got a relatively complex platformio.ini
file which you can see here. It uses extends
quite a bit to reduce redundancy, but this seems to have confused the code that populates the Tasks / Build menus.
Is this an expected behavior?
If this is the potential result of a syntax error, is there a way to simply run a syntax check on the platformio.ini
file?
