I have an Arduino Mega 2560 Rev 3 that I have flashed with HoodLoader2 so that I can use the Mega as a HID input device. I have uploaded an example sketch to the arduino using the standard Arduino IDE and verified it works, so now I am attempting to do the same with the PlatformIO IDE, as I don’t want to write my large project with the Arduino IDE. I’m attempting to follow the instructions laid out in this topic but I’m running into a few issues.
Firstly, I was getting errors about USB_PID/USB_VID being undefined preproc symbols, so I copied all of the boards.txt
file from the HoodLoader2 repository into .platformio\packages\framework-arduino-avr\boards.txt
, thinking that this would define those USB constants, but that did not work. I then added this to my build.extra_flags
in the board JSON file: -DUSB_PID=0x484C -DUSB_VID=0x2341
. This resolved those errors, but I thought it shouldn’t be necessary.
I’m also noticed that the RAM/Flash usage that the platformio command reports seems to be based on the 16u2 chip on my Mega, and not on the 2560 itself, am I really limited to such little space when using this method?
Finally, when attempting to upload my program firmware, the upload process seems to hang forever, and I can’t figure out why. This is the output that I’m getting:
> Executing task: C:\Users\Nate Mara\.platformio\penv\Scripts\platformio.exe run --target upload <
Processing mega (platform: atmelavr; framework: arduino; board: HoodLoader2atmega16u2)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/HoodLoader2atmega16u2.html
PLATFORM: Atmel AVR 2.1.0 > HoodLoader2 16u2 Mega
HARDWARE: ATMEGA16U2 16MHz, 512B RAM, 12KB Flash
- framework-arduino-avr 5.0.0
Found 6 compatible libraries
|-- <HID-Project> 2.6.1
| |-- <HID> 1.0
Checking size .pio\build\mega\firmware.elf
RAM: [==== ] 36.7% (used 188 bytes from 512 bytes)
Flash: [==== ] 44.2% (used 5434 bytes from 12288 bytes)
AVAILABLE: avr109
CURRENT: upload_protocol = avr109
Looking for upload port...
Auto-detected: COM7
Waiting for the new upload port...
Uploading .pio\build\mega\firmware.hex
It hangs forever at that Uploading
step.
This is my platformio.ini file:
[env:mega]
board = HoodLoader2atmega16u2
; board = megaatmega2560
HID-Project
And this is my boards/HoodLoader2atmega16u2.json
file:
"build": {
"core": "arduino",
"extra_flags": "-DARDUINO_ARCH_AVR -DARDUINO_AVR_HOODLOADER2 -DMAGIC_KEY_POS=(RAMEND-1) -DUSB_EP_SIZE=16 -DUSB_PID=0x484C -DUSB_VID=0x2341",
"f_cpu": "16000000L",
"hwids": [["0x2341", "0x484C"]],
"mcu": "atmega16u2",
"variant": "HoodLoader2"
"frameworks": ["arduino", "simba"],
"fuses": {
"efuse": "0x05",
"hfuse": "0xD8",
"lfuse": "0xFF",
"lock": "0x3F"
"name": "HoodLoader2 16u2 Mega",
"upload": {
"maximum_ram_size": 512,
"maximum_size": 12288,
"protocol": "avr109",
"disable_flushing": true,
"require_upload_port": true,
"wait_for_upload_port": true,
"speed": 57600
"url": "http://www.arduino.org/products/boards/4-arduino-boards/arduino-uno",
"vendor": "Arduino"
Am I missing something about the proper setup for this environment?
Edit:
the program I’m trying to upload:
#include "HID-Project.h"
void setup()
Keyboard.begin();
void loop()
Keyboard.println("HELLO");
delay(10000);
