I created two projects, and want to work simultaneously on them (Split screen code & split terminals).
I was able to upload the code to both boards using the following commands, but it stopped working after a couple of uploads.
pio run -t upload -e slave
and
pio run -t upload -e master
My paltformio.ini files look like this:
[env:master]
platform = teensy
board = teensy35
build_flags = -D TEENSY_OPT_FASTER
upload_protocol = teensy-cli
upload_port = COM17
monitor_port = COM17
and
[env:slave]
platform = teensy
board = teensy35
upload_port = COM16
monitor_port = COM16
I also tried uploading using the following command:
pio run -t upload --upload-port COM16 -e slave
But it fails as below. (Unable to access COM17, which is not the port I want to upload to!)
PS C:\Users\x\Documents\PlatformIO\Projects\timesync_slave> pio run -t upload -e slave -v
Processing slave (platform: teensy; board: teensy35; framework: arduino; build_flags: -D TEENSY_OPT_FASTER; upload_protocol: teensy-cli; upload_port: COM16; monitor_port: COM16; monitor_speed: 115200)
----------------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy35.html
PLATFORM: Teensy (4.15.0) > Teensy 3.5
HARDWARE: MK64FX512 120MHz, 255.99KB RAM, 512KB Flash
DEBUG: Current (jlink) External (jlink)
- framework-arduinoteensy 1.156.0 (1.56)
- tool-teensy 1.155.0 (1.55)
- toolchain-gccarmnoneeabi 1.50401.190816 (5.4.1)
Found 92 compatible libraries
|-- <Time> 1.6.1 (C:\Users\x\.platformio\packages\framework-arduinoteensy\libraries\Time)
arm-none-eabi-g++ -o .pio\build\slave\firmware.elf -T mk64fx512.ld -Wl,--gc-sections,--relax -mthumb -mcpu=cortex-m4 -Wl,--defsym=__rtc_localtime=1650860046 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -O2 -fsingle-precision-constant .pio\build\slave\src\main.cpp.o -LC:\Users\2cb\.platformio\packages\framework-arduinoteensy\cores\teensy3 -L.pio\build\slave -Wl,--start-group .pio\build\slave\lib5f2\libTime.a .pio\build\slave\libFrameworkArduino.a
-larm_cortexM4lf_math -lm -lstdc++ -Wl,--end-group
MethodWrapper(["checkprogsize"], [".pio\build\slave\firmware.elf"])
RAM: [ ] 1.7% (used 4376 bytes from 262136 bytes)
Flash: [ ] 3.4% (used 17948 bytes from 524288 bytes)
.pio\build\slave\firmware.elf :
section size addr
.text 15592 0
.fini 4 15592
.usbdescriptortable 160 536805376
.dmabuffers 408 536805888
.usbbuffers 864 536806296
.data 2356 536807160
.bss 588 536809516
.ARM.attributes 48 0
.comment 110 0
.debug_frame 724 0
Total 20854
arm-none-eabi-objcopy -O ihex -R .eeprom .pio\build\slave\firmware.elf .pio\build\slave\firmware.hex
<lambda>(["upload"], [".pio\build\slave\firmware.hex"])
AVAILABLE: jlink, teensy-cli, teensy-gui
CURRENT: upload_protocol = teensy-cli
teensy_reboot -s
Unable to open COM17 for reboot request
Windows Error Info: Access is denied.
more ideas... https://forum.pjrc.com/threads/40632?p=126667&viewfull=1#post126667
teensy_loader_cli -mmcu=mk64fx512 -w -s -v .pio\build\slave\firmware.hex
Teensy Loader, Command Line, Version 2.2
Read ".pio\build\slave\firmware.hex": 17952 bytes, 3.4% usage
Soft reboot is not implemented for Win32
Waiting for Teensy device...
(hint: press the reset button)
Note that despite having upload port set to COM16 in both my ini file and command line argument, it tries to upload to COM17, which is not the port I’m trying to upload to. What am I missing?
Thanks!
