Excellent! Never underestimate the power of a quick Serial.println when trying to debug. It’s what I’ve been doing most of my working life!
Cheers,
Norm.
Cheers,
Norm.
The general docs “platformio.ini” (Project Configuration File) — PlatformIO latest documentation state
Multiple value options can be specified in two ways:
- Split values with “, ” (comma + space)
- Multi-line format, where each new line starts with at least two spaces
Hi @maxgerhardt,
thanks for the link. When I mentioned that there was no mention of having to start each line with spaces or tabs, I was referring to the link I posted (above) to the monitor_flags docs. Happy that the need for spaces etc is documented elsewhere.
I hadn’t used monitor_flags up until then, and didn’t initially spot the example’s leading spaces/tabs until I tried it without and it failed to work.
Cheers,
Norm.
Thanks for the information sharing.
Hi, thank you for all the info above. However, I couldn’t manage to type anything into the terminal. Is there any setting I missed? I already added send_on_enter in the filter.
If you enable the “echo” flag, you would be able to see what you typed. Otherwise, just hit enter and what you typed would be sent to the device, it just won’t show up in the terminal
Use this Serial monitor extension thats the best way to use serial monitor in vs code ![]()
