If i have something like:
lib_deps = ArduinoJson ESPAsyncTCP ESPAsyncUDP
Is there a simple way to automatically fetch those deps but in local directory?
Just need to clarify - do you mean:
a) fetched from a local source? or;
b) fetched to a local source?
If b) this is what happens already… they get downloaded in .piolibdeps
/ .pio/libdeps
(depending on whether you are running PIO v3 or v4). You can change that folder to something else if you want by using the libdeps_dir
parameter - note it’s a global parameter for that project, so goes in the [platformio]
block, not the environment specific [env:whatever-name]
block(s).
If you want a) … maybe the lib_extra_dirs
parameter?
pio lib install
without any arguments.
