I’m looking to include some device-specific configurations as header files if they exist, and fall back to a default if the headers don’t exist. This would be flexible based on the computing unit’s hostname (i.e. unit01
, unit02
, etc.).
I set up my PLATFORMIO_SRC_BUILD_FLAGS
environment variable as the following:
export PLATFORMIO_SRC_BUILD_FLAGS="-I include/unit_config/$(hostname -s) -I include/unit_config/default"
I have the following directory structure under include/unit_config
├── default
│ ├── device1_config.h
│ └── device2_config.h
├── unit01
├── unit02
│ └── device1_config.h
├── unit03
As far as I can tell, this should load unit-specific device configurations if they exist under the unit folders, and the default configurations if the unit-specific device configurations don’t exist. No matter how many times I #include "device1_config.h
, I should always load the unit-specific file if it exists.
I have two concerns: can I rely on the order provided in PLATFORMIO_SRC_BUILD_FLAGS
to be deterministic? Is there a standard, less-hacky approach to including headers based on the specific hardware platform?
Thanks!
