I have a folder, as below:
top-level/
CMakeLists.txt. <===== A
projectB/
platformio.ini <============ With environments [env:B_X], [env:B_Y] etc.
src/
CMakeLists.txt. <===== B
projectC/
platformio.ini <============ With environments [env:C_X], [env:C_Y] etc.
src/
CMakeLists.txt <===== C
I want to be able to invoke cmake at the top level directory (corresponding to CMakeLists.txt # A), and build specific environments from within my projectB
and projectC
folders using calls to add_subdirectory(projectB)
and add_subdirectory(projectC)
. For example, I want the following environments built/flashed/monitored under the projectB and projectC folders:
ProjectB:
[env:B_X]
[env:B_Y]
ProjectC:
[env:C_X]
[env:C_Y]
… and I want the following pio commands run for the below targets:
Build:
pio run
Flash:
pio flash
Monitor:
pio monitor
I’m looking for advice on what the contents of the respective CMakeLists.txt files – #A, #B and #C – need to be, to create the build
, flash`` and
monitor``` targets above.
My thinking is that I need to use cmake’s add_custom_command()
function somewhere, to trigger calls to pio run flash
etc, but I’m a cmake newbie, and need some handholding with this.
Example snippets or github link would be greatly appreciated!
