I started to touch AVR and PlatrformIO and play with them. What I’m doing and why isn’t important, it’s just for fun and studying.
At first, I wrote ISR in my main source file. It worked perfectly, as I expected.
Further, I decided to create a library in directory lib
, put there one header and one cpp file.
The last one contains ISR:
ISR(USART_UDRE_vect, ISR_NAKED) {
asm volatile(
"\n\t"
"reti\n\t"
:[USART_B]"M"(&UCSR0B)...
Then I run pio run
and found, that this ISR was not put into firmware
N-Ryzhkov-MBP:ser namezys$ avr-objdump -S .pio/build/uno/firmware.elf
.pio/build/uno/firmware.elf: file format elf32-avr
Disassembly of section .text:
00000000 <__vectors>:
0: 0c 94 34 00 jmp 0x68 ; 0x68 <__ctors_end>
4: 0c 94 3e 00 jmp 0x7c ; 0x7c <__bad_interrupt>
... (everything is same)
64: 0c 94 3e 00 jmp 0x7c ; 0x7c <__bad_interrupt>
what I’m doing wrong?
