I installed an update today which somehow broke things, so I decided to just reinstall. I downloaded the installer, when I run it Atom gets installed, but then it hangs (see below). I’ve retried this several times, always hangs at the same spot.
Could you try this solution?
Tried it. Unfortunately, it hangs at the same spot.
Please upgrade to PlatfromIO 1.3.4. Do you still have this issue?
Trying this again 6 months later, with the latest platformio install package, and… still hangs, at same spot.
Please remove %HOME_DIR%/.platformio/penv
folder and restart IDE.
Thanks a lot for debug session! Fixed in
And thank you! Nice to make your acquaintance.
