I got the following error for Visual Studio Code and Atom…
I tried reinstalling Platformio, rebooting, running as admin.
It’s been like this for at least a month now…
Can’t find any information about it.
Thank you for your help
Error: Conda Virtualenv:
# >>>>>>>>>>>>>>>>>>>>>> ERROR REPORT <<<<<<<<<<<<<<<<<<<<<<
File "D:\anaconda\lib\site-packages\conda\exceptions.py", line 1074, in __call__
return func(*args, **kwargs)
File "D:\anaconda\lib\site-packages\conda\cli\main.py", line 84, in _main
exit_code = do_call(args, p)
File "D:\anaconda\lib\site-packages\conda\cli\conda_argparse.py", line 82, in do_call
exit_code = getattr(module, func_name)(args, parser)
File "D:\anaconda\lib\site-packages\conda\cli\main_create.py", line 37, in execute
install(args, parser, 'create')
File "D:\anaconda\lib\site-packages\conda\cli\install.py", line 116, in install
if context.use_only_tar_bz2:
File "D:\anaconda\lib\site-packages\conda\base\context.py", line 666, in use_only_tar_bz2
import conda_package_handling.api
File "D:\anaconda\lib\site-packages\conda_package_handling\api.py", line 3, in <module>
from libarchive.exception import ArchiveError as _LibarchiveArchiveError
File "D:\anaconda\lib\site-packages\libarchive\__init__.py", line 1, in <module>
from .entry import ArchiveEntry
File "D:\anaconda\lib\site-packages\libarchive\entry.py", line 6, in <module>
from . import ffi
File "D:\anaconda\lib\site-packages\libarchive\ffi.py", line 48, in <module>
libarchive = ctypes.cdll.LoadLibrary(libarchive_path)
File "D:\anaconda\lib\ctypes\__init__.py", line 434, in LoadLibrary
return self._dlltype(name)
File "D:\anaconda\lib\ctypes\__init__.py", line 356, in __init__
self._handle = _dlopen(self._name, mode)
TypeError: LoadLibrary() argument 1 must be str, not None
