I’m working with platformio-cli on linux fedora 32-bit and ubuntu20.04 64-bit. Building of the simple arduino blink application on platform infineonxmc does not work since the last update. Error messages after pio run start with:
Ubuntu 20.04
UnicodeDecodeError: ‘utf-8’ codec can’t decode byte 0x92 in position 257: invalid start byte:
File “/home/user/.platformio/penv/lib/python3.8/site-packages/platformio/builder/main.py”, line 168:
File “/home/user/.platformio/packages/tool-scons/script/…/engine/SCons/Script/SConscript.py”, line 597:
Fedore 32-Bit
UnicodeDecodeError: ‘utf8’ codec can’t decode byte 0x92 in position 257: invalid start byte:
File “/usr/lib/python2.7/site-packages/platformio/builder/main.py”, line 156:
File “/home/user/.platformio/packages/tool-scons/script/…/engine/SCons/Script/SConscript.py”, line 541:
Anyway, the issue is related to the 1.1.4 update to platformio-infineonxmc, and is one of the weirdest of errors… one of the libraries has a Unicode apostrophe in it’s library manifest… it’s been identified, but they haven’t bothered fixing it yet. I’ve just done a PR to fix it so hopefully it will be addressed soon!
In the meantime, either use the 1.1.3 version of the framework (i.e. platformio-infineonxmc@1.1.3 in your platformio.ini) OR patch the file locally by editing ~/.platformio/packages/framework-arduinoxmc/libraries/BGT24LTR11-Pulsed-Doppler-Radar/library.properties and replacing the gobbledygook apostrophe in paragraph=Infineon's 24 GHz with a normal one.
Hi Peter,
thanks a lot for your solution and the fast response! I replaced the apostrophe and everything works like before. Is there a possibility to see which file causes the error?
I was testing with a XMC2Go board. For a control application I want to use a 16-pin TSSOP version of XMC1100 (cheap, enough processing power, flash and ram for a lot of applications). I made a simple test board (controller and 2 leds), adapted the xmc1100_xmc2go board file and the pins_arduino.h file and use a modified XMC2Go board for programming.
Not really, because it is a very unusual error. The giveaway here that it was a library was when the error occured… the build proper hadn’t started… it was at the stage the Library Depenecy Finder was still scanning stuff and putting together the library tree…
- framework-arduinoxmc 1.4.0
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x92 in position 257: invalid start byte:
That at least indicated it wasn’t related to a user code error.
