fr1
5
[platformio]
default_envs = esp8266, esp32
[env] ;Common is done for all environments
monitor_flags= --raw
lib_extra_dirs =
./shared-config
bblanchon/ArduinoJson @ ^6.17.2
adafruit/Adafruit ADS1X15 @ ^1.1.1
adafruit/Adafruit MCP4728 @ ^1.0.7
adafruit/Adafruit NeoPixel @ ^1.7.0
arduino-libraries/NTPClient @ ^3.1.0
test_build_project_src = true ;The test protocol will build the contents of the src folder when running tests. Allows us to test functions inside src
; ==== STATIC CHECKING ====
check_tool = cppcheck ; pvs-studio, cppcheck, clangtidy
check_flags =
cppcheck: --enable=all
cppcheck: --inline-suppr
cppcheck: --suppress=*:.pio/libdeps/*
check_severity = medium, high
check_patterns =
src
lib
include
[extra]
extra_scripts_default =
shared/moveOutputBinaries.py
build_flags_default =
-DDEBUG_ESP_PORT=Serial
-DDEBUG_BUILD
-DWEBSOCKET_DISABLED
!python shared/GetCurrentDateTime.py
!python shared/GetGitHash.py
; -DDEBUG_ESP_OOM ;https://docs.platformio.org/en/latest/platforms/espressif8266.html#debug-level
; -Wl,-Map,output.map ;Creates a map file to figure out relative sizes of included stuff
; -DDEBUG_DISABLED ;Disables the Remote Debug - Telnet debugging
;For when debugging
; build_unflags = -Os
; build_flags = -O1 -g3 -ggdb
;==========ESP32===========
[env:esp32]
build_type = debug
debug_tool = esp-prog
; monitor_filters = esp32_exception_decoder
${extra.build_flags_default}
extra_scripts = ${extra.extra_scripts_default}
debug_init_break = tbreak setup
;========ESP8266===========
[env:esp8266]
platform = espressif8266
board = nodemcu
build_type = debug
board_build.ldscript = eagle.flash.4m1m.ld ;Sets the flash sizes properly so SPIFFS is last 1MB starting at 0x30000
[env:native_unit_testing]
platform = native
build_type = debug
-I"include/unit_testing" ;Includes Arduino.h for native builds
; -Wall -fprofile-arcs -ftest-coverage -lgcov --coverage
