PlatformIO Community
Impossible to import espidf-blink
I try to import an example project create by platformio call espidf-blink, when I click on import avec few second I have an error message :
PIO Core Call Error: "Updating metadata for the vscode IDE...
Error: Processing esp32dev (platform: espressif32; framework: espidf; board: esp32dev)
PLATFORM: Espressif 32 (5.0.0) > Espressif ESP32 Dev Module
 - framework-espidf @ 3.40401.0 (4.4.1)
 - tool-cmake @ 3.16.4
 - tool-idf @ 1.0.1
 - tool-mconf @ 1.4060000.20190628 (406.0.0)
 - tool-ninja @ 1.9.0
-- The C compiler identification is unknown
-- The CXX compiler identification is unknown
-- The ASM compiler identification is GNU
-- Found assembler: C:/Users/thoma/.platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc.exe
-- Configuring incomplete, errors occurred!
See also "C:/Users/thoma/Documents/PlatformIO/Projects/220711-190730-espidf-blink/.pio/build/esp32dev/CMakeFiles/CMakeOutput.log".
See also "C:/Users/thoma/Documents/PlatformIO/Projects/220711-190730-espidf-blink/.pio/build/esp32dev/CMakeFiles/CMakeError.log".
CMake Warning at C:/Users/thoma/.platformio/packages/framework-espidf/tools/cmake/git_submodules.cmake:1 (find_package):
 By not providing "FindGit.cmake" in CMAKE_MODULE_PATH this project has
 asked CMake to find a package configuration file provided by "Git", but
 CMake did not find one.
 Could not find a package configuration file provided by "Git" with any of
 the following names:
 GitConfig.cmake
 git-config.cmake
 Add the installation prefix of "Git" to CMAKE_PREFIX_PATH or set "Git_DIR"
 to a directory containing one of the above files. If "Git" provides a
 separate development package or SDK, be sure it has been installed.
 C:/Users/thoma/.platformio/packages/framework-espidf/tools/cmake/idf.cmake:39 (include)
 C:/Users/thoma/.platformio/packages/framework-espidf/tools/cmake/project.cmake:12 (include)
 CMakeLists.txt:2 (include)
CMake Warning at C:/Users/thoma/.platformio/packages/framework-espidf/tools/cmake/git_submodules.cmake:4 (message):
 Git executable was not found. Git submodule checks will not be executed.
 If you have any build issues at all, start by adding git executable to the
 PATH and rerun cmake to not see this warning again.
CMake Error at C:/Users/thoma/.platformio/packages/framework-espidf/tools/cmake/kconfig.cmake:1 (include):
 include could not find load file:
 ExternalProject
 C:/Users/thoma/.platformio/packages/framework-espidf/tools/cmake/idf.cmake:41 (include)
CMake Error: File C:/Users/thoma/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeSystem.cmake.in does not exist.
CMake Error at C:/Users/thoma/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeDetermineSystem.cmake:185 (configure_file):
 configure_file Problem configuring file
 C:/Users/thoma/.platformio/packages/framework-espidf/tools/cmake/project.cmake:290 (__project)
 CMakeLists.txt:3 (project)
CMake Error: Could not find cmake module file: CMakeSystemSpecificInitialize.cmake
CMake Error at C:/Users/thoma/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeCompilerIdDetection.cmake:26 (list):
 list sub-command REMOVE_ITEM requires two or more arguments.
 C:/Users/thoma/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeDetermineCompilerId.cmake:211 (compiler_id_detection)
 C:/Users/thoma/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeDetermineCompilerId.cmake:230 (CMAKE_DETERMINE_COMPILER_ID_WRITE)
 C:/Users/thoma/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeDetermineCompilerId.cmake:32 (CMAKE_DETERMINE_COMPILER_ID_BUILD)
 C:/Users/thoma/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeDetermineCCompiler.cmake:116 (CMAKE_DETERMINE_COMPILER_ID)
 C:/Users/thoma/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeDetermineCXXCompiler.cmake:111 (CMAKE_DETERMINE_COMPILER_ID)
CMake Error: Could not find cmake module file: CMakeSystemSpecificInformation.cmake
CMake Error at C:/Users/thoma/.platformio/packages/tool-cmake/share/cmake-3.16/Modules/CMakeCInformation.cmake:105 (cmake_initialize_per_config_variable):
 Unknown CMake command "cmake_initialize_per_config_variable".
CMake Error: Could not find cmake module file: CMakeTestCCompiler.cmake
CMake Error: Could not find cmake module file: CMakeTestCXXCompiler.cmake
CMake Error: Could not find cmake module file: CMakeTestASMCompiler.cmake
========================== [FAILED] Took 3.86 seconds =========================="
Do I miss something?
I use pio extention on VS code and I try to remove and reinstall pio and package?
Thanks for you help
Sounds like an ESP compiler mistake somewhere.
This seems to generate an error file C:/Users/thoma/Documents/PlatformIO/Projects/220711-190730-espidf-blink/.pio/build/esp32dev/CMakeFiles/CMakeError.log
Is there any more information on this file?
I Think the problem come from the fact that old ESP board such as ESP32dev don’t fit with the new version of esp_idf :
That must be change in their exemple!
For my project I try to use use old version of esp_idf@4.4.0.
I will let you know if it’s solve the problem
There is 2 different option to import espidf-blink with esp-idf5.0.0 and esp-idf4.4.0 works with esp-idf4.4.0
