I tried this week-end the library downloader of platformIO using :
platformio lib search <something>
and
platformio lib install <IDofsomething>
and it worked on my computed under Windows 10.
I just tried on my linux session this morning (exactly the same) but it didn’t seem to work. I get the following error when running the install command :
byran@xxx:/media/byran/Données/PlatformIOProjectsLinux/Essai3$ platformio lib install 91
Library Storage: /media/byran/Données/PlatformIOProjectsLinux/Essai3/.piolibdeps
LibraryManager: Installing id=91
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/platformio/__main__.py", line 108, in main
cli(None, None, None)
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/click/core.py", line 700, in __call__
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/click/core.py", line 680, in main
rv = self.invoke(ctx)
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/click/core.py", line 1027, in invoke
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/click/core.py", line 873, in invoke
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/click/core.py", line 508, in invoke
return callback(*args, **kwargs)
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/click/decorators.py", line 26, in new_func
return f(get_current_context().obj, *args, **kwargs)
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/platformio/commands/lib.py", line 84, in lib_install
lm.install(library, silent=silent, interactive=interactive)
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/platformio/managers/lib.py", line 156, in install
_requirements, silent, trigger_event)
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/platformio/managers/package.py", line 451, in install
pkg_dir = self._install_from_piorepo(name, requirements)
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/platformio/managers/lib.py", line 138, in _install_from_piorepo
requirements)
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/platformio/managers/package.py", line 214, in _install_from_url
dlpath = self.download(url, tmp_dir, sha1)
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/platformio/managers/package.py", line 296, in download
fd = FileDownloader(url, dest_dir)
File "/home/byran/.atom/packages/platformio-ide/penv/local/lib/python2.7/site-packages/platformio/downloader.py", line 38, in __init__
self.set_destination(join(dest_dir, self._fname))
File "/home/byran/.atom/packages/platformio-ide/penv/lib/python2.7/posixpath.py", line 73, in join
path += '/' + b
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 17: ordinal not in range(128)
`pip install -U platformio` command
http://docs.platformio.org/en/stable/faq.html
https://github.com/platformio/platformio/issues
Exception AttributeError: "'FileDownloader' object has no attribute '_request'" in <bound method FileDownloader.__del__ of <platformio.downloader.FileDownloader object
at 0x7fa484e9bd50>> ignored
Does anyone have an idea about how to solve that problem ?
Cheers,
Byran
