I have a sketch that is a simple example of using the ESP32TimerInterrupt library. The sketch was downloaded from the library’s GitHub repository. I have opened the sketch in the Arduino IDE and after adding the ESP32TimerInterrupt library, it builds and runs.
However, when I import that sketch into VSCode/PlatformIO, add the library, the build fails with some undefined symbols.
I am at a loss as to why this does not work, any pointers on how to resolve it would be much appreciated,
Sid
Please post the exact platformio.ini
and the link to the example you’re compiling.
Thank you:
lib_deps = khoih-prog/ESP32TimerInterrupt@^2.0.1
build_type = debug
And the example project → https://github.com/khoih-prog/ESP32TimerInterrupt/blob/master/examples/Change_Interval/Change_Interval.ino
Sid
sidprice:
khoih-prog
I’ve noticed that programs from this author often need lib_ldf_mode = chain+
or (deep+
). Can you add that in the platformio.ini
and retry?
@maxgerhardt Thank you I tried both of the following, the errors did not change each time.
lib_ldf_mode = deep+
and
Sid
The project does build with the latest 2.0.2 core.
>pio run
Processing esp32dev (platform: https://github.com/Jason2866/platform-espressif32.git; board: esp32dev; framework: arduino)
------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
FILESYSTEM spiffs
PLATFORM: Espressif 32 (2.0.3+sha.35ffd4c) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 2.0.3
- tool-esptoolpy 1.30201.220126 (3.2.1)
- tool-mklittlefs 1.203.210628 (2.3)
- toolchain-xtensa-esp32 8.4.0+2021r2-patch2
Found 32 compatible libraries
|-- <ESP32TimerInterrupt> 2.0.1
Compiling .pio\build\esp32dev\src\main.cpp.o
Generating partitions .pio\build\esp32dev\partitions.bin
Archiving .pio\build\esp32dev\libFrameworkArduinoVariant.a
Indexing .pio\build\esp32dev\libFrameworkArduinoVariant.a
Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\HardwareSerial.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPAddress.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\IPv6Address.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\MD5Builder.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Print.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Stream.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\StreamString.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\Tone.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\USB.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\USBCDC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\USBMSC.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\WMath.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\WString.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\base64.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\cbuf.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-adc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-bt.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-cpu.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-dac.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-gpio.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-i2c-slave.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-i2c.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-ledc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-matrix.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-misc.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-psram.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-rmt.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-sigmadelta.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-spi.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-time.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-timer.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-tinyusb.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-touch.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\esp32-hal-uart.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\firmware_msc_fat.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cdecode.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\libb64\cencode.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\main.cpp.o
Compiling .pio\build\esp32dev\FrameworkArduino\stdlib_noniso.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_pulse.c.o
Compiling .pio\build\esp32dev\FrameworkArduino\wiring_shift.c.o
Archiving .pio\build\esp32dev\libFrameworkArduino.a
Indexing .pio\build\esp32dev\libFrameworkArduino.a
Linking .pio\build\esp32dev\firmware.elf
Retrieving maximum program size .pio\build\esp32dev\firmware.elf
Checking size .pio\build\esp32dev\firmware.elf
RAM: [ ] 4.3% (used 14060 bytes from 327680 bytes)
Flash: [= ] 10.6% (used 139109 bytes from 1310720 bytes)
Building .pio\build\esp32dev\firmware.bin
esptool.py v3.2.1
Creating esp32 image...
Merged 2 ELF sections
============================================= [SUCCESS] Took 13.47 seconds =============================================
please use the platformio.ini
platform = https://github.com/Jason2866/platform-espressif32.git
and use the CLI to execute a
pio platform update https://github.com/Jason2866/platform-espressif32.git
to update a potentially outdated platform version.
Thank you very much, great progress. I now get only a final link error:
c:/users/sidpr/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: reopening c:/users/sidpr/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/no-rtti/crti.o: No such file or directory
c:/users/sidpr/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: final link
failed: No such file or directory
*** [.pio\build\esp32dev\firmware.elf] Error 1
Hm, looks your either antivirus software interfererd here or your toolchain got corrupted.
If you build it twice, does it link?
If not, remove the folder c:/users/sidpr/.platformio/packages/toolchain-xtensa-esp32/
and build again.
Wonderful! A second build did the trick, I can can build, flash, and debug (using ESP-Prog.
One concern is about using a fork of the Espressif platform. Is that an OK thing to do as this project moves forwards and perhaps Espressif makes updates?
Well using the custom platform is currently the only way to get the 2.0.2 core that is capable of compiling libraries depending on this core version. But you can have more safety against changes by fixing the commit hash of the used platform in place, so it should always build.
platform = https://github.com/Jason2866/platform-espressif32.git#52fb773
Once PlatformIO devs release a new version of the regular espressif32
platform with 2.0.2 core support, it should however be used instead.
OK, many thanks for your help. Very much appreciated.
